I was trying to partition my Jetson nano sd card coz it was showing me 14gb only but in reality it was 128gb. I made something wrong in terminal and Jetson nano is not working anymore. It is freezing in Nvidia Logo screen. I tried system reset by connecting pins 5 and 6 but it didn’t work out. Can you tell how can I fix my Jetson nano completely. Pls mention the whole process.
This topic will get better exposure in the Jetson forums. I have moved it over for you.
hi how can I see that thread ?
Hi shirshak.pattnaik81,
Are you using the devkit or custom baord?
Are you using standalone Ubuntu 18.04 as your host PC?
If you use the devkit from NVIDIA and standalone Ubuntu 18.04.
You could refer to the following instruction to re-flash the board with SDK Manager.
Install Jetson Software with SDK Manager :: NVIDIA SDK Manager Documentation
Hi Kevin,
I am using devkit b01 board but I don’t have a Ubuntu 18.04 host pc. What shall I do
Please help to get a Ubuntu18.04 PC or create dual boot on your current host PC first. Ubuntu 18.04 is really important to develop Jetson no matter using SDKM or flash script for your devkit.
What did you make to cause the board not working?
I was using 128gb sd card but in Jetson it showed me 14gb. I tried to play with partitions and then I ended up like this ?
Can we do it in Ubuntu 18.04 VM ( Virtual Machine) ?
You need to clean up the SD card and format it as ext4 first.
If you really do not have a standalone Ubuntu, you could try to use VM. Please make sure the VM could recognize the board during flash through USB.
Hi Kevin, when I try to use to nvidia SDK to flash the Jetson nano in recovery mode…it is getting stuck at 99%.
Could you help to provide the flash log for further check?
13:37:26 INFO: Drivers for Jetson - target_image: [host] [sudo] password for vboxuser:
13:37:26 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: verifying checksum of /home/vboxuser/Downloads/libnvidia-container1_1.7.0-1_arm64.deb
13:37:26 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: verifying checksum of /home/vboxuser/Downloads/libnvidia-container-tools_1.7.0-1_arm64.deb
13:37:26 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: Found file /home/vboxuser/Downloads/libnvidia-container0_0.10.0+jetpack_arm64.deb with correct checksum, skip downloading.
13:37:26 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: verifying checksum of /home/vboxuser/Downloads/nvidia-container-toolkit_1.7.0-1_arm64.deb
13:37:27 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: verifying checksum of /home/vboxuser/Downloads/nvidia-container-runtime_3.7.0-1_all.deb
13:37:27 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: Found file /home/vboxuser/Downloads/libnvidia-container1_1.7.0-1_arm64.deb with correct checksum, skip downloading.
13:37:27 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: verifying checksum of /home/vboxuser/Downloads/nvidia-docker2_2.8.0-1_all.deb
13:37:27 INFO: Multimedia API - target: verifying checksum of /home/vboxuser/Downloads/nvidia-l4t-jetson-multimedia-api_32.7.3-20221122092935_arm64.deb
13:37:27 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: Found file /home/vboxuser/Downloads/nvidia-container-runtime_3.7.0-1_all.deb with correct checksum, skip downloading.
13:37:27 INFO: Nsight Systems CLI - target: verifying checksum of /home/vboxuser/Downloads/nsight-systems-linux-tegra-public-2021.5.4.19-e642d4b_2021.5.4.19-1_arm64.deb
13:37:27 INFO: DeepStream - target: verifying checksum of /home/vboxuser/Downloads/deepstream-6.0_6.0.1-1_arm64.deb
13:37:27 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: Found file /home/vboxuser/Downloads/nvidia-docker2_2.8.0-1_all.deb with correct checksum, skip downloading.
13:37:27 INFO: Drivers for Jetson - target_image: exec_command: /tmp/tmp_NV_L4T_DRIVERS_T210_COMP.sh
13:37:27 INFO: Nsight Systems CLI - target: Found file /home/vboxuser/Downloads/nsight-systems-linux-tegra-public-2021.5.4.19-e642d4b_2021.5.4.19-1_arm64.deb with correct checksum, skip downloading.
13:37:27 INFO: Multimedia API - target: Found file /home/vboxuser/Downloads/nvidia-l4t-jetson-multimedia-api_32.7.3-20221122092935_arm64.deb with correct checksum, skip downloading.
13:37:28 INFO: CUDA Toolkit for L4T - target: Found file /home/vboxuser/Downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb with correct checksum, skip downloading.
13:37:28 INFO: File System and OS - target_image: Found file /home/vboxuser/Downloads/Tegra_Linux_Sample-Root-Filesystem_R32.7.3_aarch64.tbz2 with correct checksum, skip downloading.
13:37:29 INFO: DeepStream - target: Found file /home/vboxuser/Downloads/deepstream-6.0_6.0.1-1_arm64.deb with correct checksum, skip downloading.
13:38:19 INFO: Drivers for Jetson - target_image: [host] [ 302.03 MB used. Disk Avail: 45.36 GB ]
13:38:19 INFO: Drivers for Jetson - target_image: command finished successfully
13:38:19 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
13:38:19 DEBUG: running command < true >
13:38:19 INFO: command finished successfully
13:38:19 DEBUG: File System and OS - target_image: using adapter to install NV_L4T_FILE_SYSTEM_AND_OS_T210_COMP@JETSON_NANO_TARGETS to /home/vboxuser/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/rootfs/
13:38:19 INFO: File System and OS - target_image: exec_command: /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_T210_COMP.sh
13:45:48 : File System and OS - target_image: WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
13:45:49 INFO: File System and OS - target_image: Get:2 Index of /ubuntu bionic-updates InRelease [88.7 kB]
13:45:49 INFO: File System and OS - target_image: Get:3 Index of /ubuntu bionic-backports InRelease [83.3 kB]
13:45:49 INFO: File System and OS - target_image: Get:4 Index of /ubuntu bionic-security InRelease [88.7 kB]
13:45:49 INFO: File System and OS - target_image: Get:5 Index of /ubuntu bionic-updates/main amd64 Packages [2,925 kB]
13:45:50 INFO: File System and OS - target_image: Get:6 Index of /ubuntu bionic-updates/main i386 Packages [1,618 kB]
13:45:50 INFO: File System and OS - target_image: Get:7 Index of /ubuntu bionic-updates/main Translation-en [535 kB]
13:45:50 INFO: File System and OS - target_image: Get:8 Index of /ubuntu bionic-updates/universe amd64 Packages [1,891 kB]
13:45:50 INFO: File System and OS - target_image: Get:9 Index of /ubuntu bionic-updates/universe i386 Packages [1,653 kB]
13:45:52 INFO: File System and OS - target_image: Fetched 8,883 kB in 3s (3,008 kB/s)
13:45:57 INFO: File System and OS - target_image: Reading package lists…
13:45:58 INFO: File System and OS - target_image: Building dependency tree…
13:45:58 INFO: File System and OS - target_image: Reading state information…
13:45:58 INFO: File System and OS - target_image: 2 packages can be upgraded. Run ‘apt list --upgradable’ to see them.
13:45:58 : File System and OS - target_image: WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
13:45:59 INFO: File System and OS - target_image: Reading package lists…
13:45:59 INFO: File System and OS - target_image: Building dependency tree…
13:45:59 INFO: File System and OS - target_image: Reading state information…
13:46:00 INFO: File System and OS - target_image: qemu-user-static is already the newest version (1:2.11+dfsg-1ubuntu7.41).
13:46:00 INFO: File System and OS - target_image: 0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
13:46:01 INFO: File System and OS - target_image: Reading package lists…
13:46:01 INFO: File System and OS - target_image: Building dependency tree…
13:46:01 INFO: File System and OS - target_image: Reading state information…
13:46:02 INFO: File System and OS - target_image: 0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
INSTALLATION FAILED
Please review the terminal tab for details. Resolve and RETRY.
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
Copyright © 2023, NVIDIA CORPORATION. All rights reserved. | NVIDIA Developer
There is a “export logs” button on sdkmanager. I would suggest to use that one and attach the full file here.
It is not a good idea to copy past some large log file directly to forum.
No need to mention the log you pasted didn’t include the error part…
SDKM_logs_2023-03-21_16-02-40.zip (292.2 KB)
Is this still from a ubuntu VM?
yes wayne.
Could you find a native ubuntu host? The flash process seems got stuck in the beginning.
oracle vm
should we use ubuntu in host pc ?
Yes, please get a non-VM ubuntu 18.04 on your x86_64 host PC.
