Jetson Nano: Green LED turns on briefly then off, no UART output
I’m having trouble with my Jetson Nano Developer Kit (SD card version). When I plug in the power, the green LED turns on briefly (a few seconds) and then turns off. I’ve tested both the micro-USB and the 5V barrel jack power inputs, and the result is the same.
To debug, I tried using UART serial output (with a USB-to-TTL adapter, 3.3V logic, 115200 baud, 8N1), but there is no output at all — not even bootloader messages or errors.
Is it possible the board’s bootloader or power management IC is damaged or locked in a failed state? Are there further recovery steps I can take given there is no UART output at all?
Thanks in advance for your support!
Did you try to reflash the SD card using SDK manager?
Are you able to make your Jetson configure in to Recovery mode before flashing from the host pc?
Hi a01379354,
Can your developer kit boot before?
Do you refer to the instruction in Jetson Nano & NX Style - Serial Debug Console - JetsonHacks to capture serial console log?
Have you tried if your devkit with force recovery state can be recognized through USB connected to your host?
You can short REC/GND before power up the board and run lsusb on your host to check.
