Hi
I have a Jetson nano emmc core module and a support board. I have ubuntu 18.04.
The download of the files is taking forever
The jetson nano is not getting detected in the SDK manager. No boards found (both LAN and usb tried)
Please help. If there is an NVIDIA office in Bangalore and a tech agent who can port the install, that would be of great help.
Chandra
Dear @anon51967133 ,
Which Jetpack version does the board has currently?
Were you able to flash the board earlier?
Is it on host?
Did you check https://developer.nvidia.com/embedded/learn/get-started-jetson-nano-devkit#setup if it helps?
The board initially came with a SD card based core module which was not working. I bought an eMMC module and this needs to be flashed using SDK manager.
I am trying jetpack 4.6 version using ubuntu 18.04 host computer.
The eMMC is not being detected.
A link can be seen here → Flash Jetson NANO module with 16GB eMMc(updated) - YouTube
What is the SDKM verison?
Hi chandra5 ,
Please make sure you are using the latest SDK Manager and check again.
Everything You Need to Set Up Your Development Environment NVIDIA SDK Manager provides an end-to-end development environment setup solution for NVIDIA’s DRIVE, Jetson, Holoscan, Rivermax, DOCA and Ethernet Switch SDKs for both host and target...
Otherwise, you can try flash image by manually.
Download the latest L4T Driver Package and Sample File System from here:
NVIDIA L4T 32.7.2 supports all Jetson modules: Jetson AGX Xavier series, Jetson Xavier NX, Jetson TX2 series, Jetson TX1, and Jetson Nano. All Jetson developer kits are also supported.
And follow Quick Start Guide to flash image on Jetson Nano.
system
Closed
October 5, 2022, 5:20am
8
