Is it possible to run turtlesim through ROS on Jetbot (jetson nano)?
kayccc
2
Hi liamhan0905,
Please refer to https://github.com/dusty-nv/jetbot_ros if can gain some ideas.
Related topics
| Use ROS on Jetson Nano | 1 | 846 | April 18, 2019 | |
| Robot could use Jetson Nano | 8 | 2057 | September 6, 2023 | |
| Check out our tutorial for using the Jetson Nano to build a small robot running ROS! | 0 | 1191 | December 3, 2019 | |
| Check out our tutorial for using the Jetson Nano to build a small robot running ROS! | 1 | 905 | December 4, 2019 | |
| Does rosserial_arduino work with Nvidia jetson nano? | 1 | 699 | August 13, 2020 | |
| Mobile Robot Platform with Jetson nano supporting ROS2, SLAM navigation | 3 | 3642 | December 3, 2022 | |
| ROS and Raspberrypi Camera V2 | 8 | 2128 | January 19, 2021 | |
| How Can I use jetbot on nano emmc module ,not on the nano sd module | 9 | 1227 | June 8, 2022 | |
| Installing ROS on Nano | 24 | 22251 | June 18, 2019 | |
| Cat watches JetBot DIY for Jetson nano 2GB | 0 | 554 | December 22, 2020 |
