For me it did thankfully. I am using HDMI and have not connected the DP pins so did not need to check that particular pin but it’s interesting what you are saying.
I would certainly refer to nano datasheet for module pin numbers first and foremost. But I see in the xlsx spread sheet they have it as 90 which reflects the Datasheet. The datasheet is the bible but I can see how easily we could use a pin number from other docs for software / DT.
Thanks for alerting me.
