I have a 4gb Jetson nano I bought in 2019. I recently flashed it with the image jetson-nano-jp461-sd-card-image
. After this the device is not booting at all. I have attached the UART log. It seems like the issue is at the very end with message - Failed to validate boot-image
. Any tips on how to fix this?
jetson_log.txt (14.2 KB)
That might be bootrom image not match with newer SW image, suggest to have a host PC with Ubuntu 18.04 to install SDK manager, then flash your device via JetPack.
Okay, I will try that, thanks!
