Jetson nano shuts down immediately
My jetson nano 4gb got boot up first time with the downloaded image from nvidia
It worked out first time with jetson username and password jetson (by default) the inital boot up using micro usb port
And then I tried to open it up again giving me the nvidia logo and draws 1amp\0.5 amp through the bench psu and shutsdown
I tried the micro usb ,barrel jack
I am using jetson nano io base a carrier board
Please record the serial console log for us to review.
Thank u so much for replying!
I did the same as the tutorial but it is giving me error 71 after i flashed with sdkmanager also it is not showing up in the list of lsusb?
Still stuck on nvidia logo after flashing and Idk what to do?
Please record the serial console log while running the SDK manager simultaneously.
it is giving me that after it was being detected and I am connecting the FR REC with the GND pins in a short circuit after flashing using the sdk manager
and also not detecting it with lsusb after i flashed what seem to be the problem?
it even gave m nvidia logo with more miserable quality after the flashing through the sdk manager
it was giving me that during flashing but I skipped downloading the sdk copmponents as I didnt know how to solve that issue
Please try to ping 192.168.55.1 to check whether connected.
Also reboot the host and run sdk manager again.
The ping works successfully but the sdkmanager still not detecting it
For the record when I tried to flash it firstly I didnt remove the force recovery pin with the GND during the flashing could it be the problem?
Thank you so much for helping tho I appreciate it
Some questions to confirm:
  • Is your ubuntu a native ubuntu or a virtual machine.
~0507
