Hi!
We are currently in the process of developing a custom carrier board for nvidia jetson nano, and had a question regarding the mipi-csi interface of the board.
The board outputs 6 CSI connectors numbered 0 to 5 inclusive.
We have problems with channels:
1: (pins 3,5,15,17). In some documentations it has a clk interface at pins 9 and 11, and on some they are marked as RESERVED.
5: (pins 40,42,64,64). This CSI interface has no clock output.
So the question is as follows. Is there a way to get six cameras up and running, at the same time? Is is possible to use pins 9 and 11 to at least get 5 cameras working? Is it allowed to feed camera from 5-th port with CSI0_CLK? Is it ok to connect all camera CLK pins directly do CSI0_CLK?
Kind regards, and thanks for the help!
