Hello there!
I recently purchased a Jetson Nano, so I’m completely new to this system. As a beginner, I have a few questions according to the general usage of this product, so I hope I can get some answers here. Thank you in advance!
- If you connect the Jetson Nano to a display with e.g. HDMI, you can edit the code in the Ubuntu interface. If I then build the chip inside a robot, how does it simply run the code I wrote? Is this automatically triggered when no display is connected?
- I saw that an internet connection is required when working with the Jetson Nano, either through an Ethernet cabel or by a WiFi adapter. Does this also apply to the "run code only-mode" described in the previous point? I won't be able to provide internet connection for a portable system in which I want to implement the Jetson Nano.
- Speaking about portable systems, how can I ensure a proper power supply without a socket? How big does the energy storage have to be? I mean, I heard from various sources that the Jetson Nano consumes a lot of power, so would e.g. a power bank with 2Ah capacity and a 5V ⎓ 2.5A output be enough?
