Hello guys im kinda new using this Jetson.
I tried to use an adapter with 5v and 2.1 AMP Micro USB and my Micro SD with the .iso from Etcher, when i plugged it, the only thing that happend in the board was that the green led turn on, when i check the monitor it doesnt recognize a signal , i check my USB keyboard and mouse and it doesnt turn on.
Any one has the same problem?
Thanks in advanced
Update
Now im using a Lab DC Power Supply with 5v and when i the usb cable with the DC Power , the amps mantain at 0.69
Hi, did you read the dev kit user guide and follow below steps? If yes, might need check if any log output.
Before using your developer kit, you need to set up a microSD card with the operating system and JetPack components. The simplest method is to download the microSD card image and follow instructions found in Getting Started with Jetson Nano Developer Kit.
In summary:
• You need a 16 GB or larger UHS-1 microSD card, HDMI or DP monitor, USB keyboard and mouse, and 5V⎓2A Micro-USB power supply.
• Download the image and write it to the microSD card.
• Insert the microSD card into the slot under the Jetson Nano module, then attach the display, keyboard, mouse, and Ethernet cable or wireless networking adapter.
• Connect the Micro-USB power supply. The developer kit powers on automatically.
For alternative methods, see How to Install JetPack, below.
Hi Trumany , i did all the steps and still nothing , no response from the HDMI
Is it possible to use UART port to get log info? Did you try other power supply? Did you change any jumper status on board? If all are normal, you might need RMA this board.
Soy de Perú, cuales el link para solicitar el RMA ?
RMA FAQ:
https://developer.nvidia.com/embedded/faq#rma-process
RMA Procedure:
- Go to http://nvidia.custhelp.com/app/home
- Select “Live Chat” from the options near the top of the page.
- Enter your personal information.
- Select the appropriate product from the drop-down list (“Tegra” in this case).
- Submit the request.
- If the Service agent is unable to resolve the technical issue, an RMA (Return Material Authorization) will be initiated.
More support information here:
https://developer.nvidia.com/embedded/support
Sorry, I don’t know of specific URLs for Peru. Your vendor from the original purchase would know.
Lo siento, no sé de URL específicas para Perú. Su proveedor de la compra original lo sabría.
