Jetson Nano with Can and Lora/GPS Hat
Hello I need help with my project.
in this project i use a can and a lora hat on my Jetson Nano. Both are controlled via spi.
The lora hat is accessing spidev0.1 and the can hat is supposed to run over can0 (spidev0.0?).
Here are two links to the hats:
https://wiki.dragino.com/index.php?title=Lora/GPS_HAT
If I enable spi and uart via jetson io, the lora hat runs.
I got the can hat to run with the help of the following instructions.
However, then the lora hat no longer runs, because this is disabled in the dts file.
I tried with the following dts file to get both to run. But then the can hat no longer runs or I get no reasonable can id.
// SPDX-License-Identifier: GPL-2.0-only
  • Jetson Device-tree overlay for
  • MCP2515
  • Copyright (c) 2020 Seeed Technology Co,Ltd - https://www.seeed.cc.
  • All rights reserved.
/dts-v1/;
/plugin/;
include <dt-bindings/pinctrl/pinctrl-tegra.h>
include <dt-bindings/gpio/tegra-gpio.h>
overlay-name = “MCP251x CAN”;
compatible = “nvidia,p3449-0000-b00+p3448-0000-b00\0nvidia,p3449-0000-a02+p3448-0000-a02”;
fragment@0 {
	target-path = "/";
	__overlay__ {
		clocks {
			can_clock: can_clock {
				compatible = "fixed-clock";
				#clock-cells = <0>;
				clock-frequency = <16000000>;
				clock-accuracy = <100>;
fragment@1 {
	target = <&spi0>;
	__overlay__ {
		#address-cells = <1>;
		#size-cells = <0>;
		spi@0 {
			status = "okay";
			compatible = "microchip,mcp2515";
			reg = <0x0>;
			spi-max-frequency = <10000000>;
			nvidia,enable-hw-based-cs;
			nvidia,rx-clk-tap-delay = <0x7>;
			clocks = <&can_clock>;
			interrupt-parent = <&gpio>;
			interrupts = <TEGRA_GPIO(Z, 0) 0x1>;
			controller-data {
				nvidia,cs-setup-clk-count = <0x1e>;
				nvidia,cs-hold-clk-count = <0x1e>;
				nvidia,rx-clk-tap-delay = <0x1f>;
				nvidia,tx-clk-tap-delay = <0x0>;
		spi@1 {
			status = "okay";
			compatible = "spidev";
			reg = <0x1>;
			spi-max-frequency = <0x1f78a40>;
			controller-data {
fragment@2 {
	target = <&spi1>;
	__overlay__ {
		#size-cells = <0>;
		spi@0 {
			status = "disabled";
		spi@1 {
			status = "okay";
			reg = <0x0>;
			interrupts = <TEGRA_GPIO(V, 0) 0x1>;
			controller-data {
fragment@3 {
	target = <&pinmux>;
	__overlay__ {
		pinctrl-names = "default";
		pinctrl-0 = <&hdr40_pinmux>;
		hdr40_pinmux: header-40pin-pinmux {
			pin19 {
				nvidia,pins = "spi1_mosi_pc0";
				nvidia,function = "spi1";
				nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
				nvidia,tristate = <TEGRA_PIN_DISABLE>;
				nvidia,enable-input = <TEGRA_PIN_ENABLE>;
			pin21 {
				nvidia,pins = "spi1_miso_pc1";
			pin23 {
				nvidia,pins = "spi1_sck_pc2";
			pin24 {
				nvidia,pins = "spi1_cs0_pc3";
				nvidia,pull = <TEGRA_PIN_PULL_UP>;
			pin37 {
				nvidia,pins = "spi2_mosi_pb4";
				nvidia,function = "spi2";
			pin22 {
				nvidia,pins = "spi2_miso_pb5";
			pin13 {
				nvidia,pins = "spi2_sck_pb6";
			pin18 {
				nvidia,pins = "spi2_cs0_pb7";
thanks for the help
Sorry for the late response, is this still an issue to support? Thanks
Not anymore. I only have the problem that I get an extremely high id with my program when I use the can_frame struct and I can’t set it to zero either.
When i set it to zero my program hangs up. (frame.can_id = 0;)
I have also tested it in an external program and I also get an id other than zero.
Test Program:
#include <stdio.h>
#include <linux/can.h>
int main(){
struct can_frame f;
printf(“ID: %d\n”, f.can_id);
return 0;
