Jetson NX frequency is low
The frequency of the NX is low. max is 953000hz, 953Mhz,the temperature of soc is 70℃,not reach the 90.
the nomal nx is 1904200 1.9Ghz.
please check it the reason.
thanks.
hello qitb,
please refer to Supported Modes and Power Efficiency.
may I know which NVPModel clock configuration you’re running with.
BTW,
you’re able to execute tegrastats utility to monitor the reported statistics,
thanks
thanks.this chip is not ok again.
