I have the same problem as many users. I have prepared my own board for the Jeston AGX and can’t get it to work.
When designing, we used the Design Guide Jetson_AGX_Orin_Series_Design_Guide_DG-10653-001_v1.6 and the diagram: Jetson_AGX_Orin_DevKit_Carrier_Board_Design_Files_A04_20221003
To start with, let’s discuss the power sequence. I use the minimum possible variant - Auto Power ON. I also don’t have an additional IC, the pins have been routed to our environmental processor, but at this stage I am also trying to manually control these signals.
Startup:
C1: 12V(SYS_VIN_HV),
C2: 5V(SYS_VIN_MV),
C3: MODULE_POWER_ON,
C4: CARRIER_POWER_ON
Current when MODULE_POWER_ON is HIGH:
12V - 0.11A,
5V - 0.25-0.31A,
Tries to approach data from UART port 3 Debug - R120 - but I get no response.
I have come to the conclusion that not using EEPROM I should modify the software. But without that, shouldn’t there be any UART communication?
I also see no sign of communication over the I2C(I2C1) bus, where the memory should be.
How can I do further debugging? I’ve looked through the documentation many times and don’t see any significant differences. The circuit responds to a change in the MODULE_POWER_ON state, but there is no other communication. Should I set any of the other signals accordingly?
To summarize the problems identified:
- no UART3 data.
- no change in the I2C1 signal(goes high and there is no response)
- no HDMI image
Additional measurements:
MODULE_SHDN_N - 1.5V
MODULE_SLEEP_N - 1.8V
SYS_RESET_N - 1.8V
CARRIER_POWER_ON 3.3V
Please help.
I have a Jetson NVIDIA 900-13701-0040-000 module, which runs on the original development board.
