What are the external storage boot options for Jetson Orin Nano? The resources available for which option?
SD cards (for Orin Nano SKU5), USB disks and NVMe SSDs are supported.
Thanks for quick reply.
- Could you please clarify what is “SKU5”. Is SKU5 is latest production version? How to purchase SKU5
- Can you share design files (schematic) for the same?
SKU5 means the Developer Kit module with an SD card slot.
https://developer.nvidia.com/downloads/assets/embedded/secure/jetson/orin_nano/docs/jetson_orin_nano_devkit_carrier_board_reference_design_files_a04_20230320.zip/
These design file does not have SD card interface. I want to use SD card on carrier board. If I get the information how SD card is interface on developmental version of Orin Nano module, then same way I can interface SD card in custom carrier board. This will help us to boot the OS from SD card (mounted custom carrier board) without any change in OS/BSP.
I think this is the one you need:
Thanks for quick reply. The shared document does not have information on SD card interface. I need SD card interface guideline. Where I want to used SD card for external storage for booting the OS.
Orin nano does not support external SD slot design. You can consider PCIe or USB devices for storage.
