I’m using Jetson Orin 32GB EVB with JP5.0 flashed.
I’m trying to activate the Jetson Power GUI, but it will not come up.
Can you please assist?
You posted in Nsight category, this should be posted in the Jetson Orin forum. I will go ahead and move it over for you.
Tom K
What is “power GUI”?
I’m referring to this feature:
https://docs.nvidia.com/jetson/archives/r34.1/DeveloperGuide/text/SD/PlatformPowerAndPerformance/JetsonXavierNxSeriesAndJetsonAgxXavierSeries.html#jetson-power-gui
To run Jetson Power GUI:
Click the nvpmodel GUI represented by an NVIDIA icon on the right side the Ubuntu desktop’s top bar.
Click the “Run Jetson Power GUI” submenu.
This GUI does not show up on my unit.
בתאריך יום ד׳, 27 באפר׳ 2022 ב-5:08 מאת WayneWWW via NVIDIA Developer Forums <nvidia@discoursemail.com>:
Hi user98065,
We can see the Jetson Power GUI pop-up on Desktop without problem.
Can you reboot and try again? or flash JP-5.0 DP again?
Hi @carolyuu ,
Reboot does not help.
I’ve installed the Orin JP5.0 using instructions in: Getting Started with Jetson AGX Orin Developer Kit | NVIDIA Developer
Hi user98065,
$ sudo /usr/share/nvpmodel_indicator/nvpmodel_indicator.pyHi,
This command:
Did not generate any error messages or prints. It simply “hangs”
Hi @carolyuu ,
I reflashed Orin using SDK manager and the issue is now resolved.
Hello, could you please tell me what have you done. Have you installed the SDK on a host running ubuntu and what did you do after this? Have you re-installed from the beginning or just something to fix the power GUI.
Thanks,
Harry
Yes, I flashed the Orin from scratch using SDK Manager installed on a host PC running Ubuntu. No ‘local’ fix for Power GUI was suggested.
בתאריך יום ב׳, 2 במאי 2022 ב-12:56 מאת Harry S. via NVIDIA Developer Forums <nvidia@discoursemail.com>:
Okay, thanks.
