Jetson ORION NX 16 GB stop working
I was working with the Jetson Orin NX using a screen, keyboard, and mouse. I had installed Node.js, npm, AngularJS, and was working with PostgreSQL 16. After turning off the Jetson Orin, it now shows only a blank screen on startup.
This is the output when I turned on the Jetson Nano.
looks like yours installations and changes effected the display manager of jetson, thats why showin back screen.
try to run from serial console and run “xrandr” command check, if display is fine or not
Please dump below the log for us to review.
  • /var/log/Xorg.0.log
  • The output of lsmod saved to a file: lsmod > lsmod.txt
  • The output of dmesg saved to a file: dmesg > dmesg.txt
  • ps aux | grep gdm3
