Jetson Source Server Migration to GitLab
We would like to give developers an update about an important change to the Jetson ecosystem. In January 2026, the Jetson source server transitioned from current nv-tegra.nvidia.com to the new gitlab.com/nvidia/nv-tegra.
What’s Changing?
  • Read-Only Mode (RO)
    nv-tegra.nvidia.com transitioned into read-only mode in January 2026 and will remain accessible until December 2026 for reference.
  • Full Migration of Data
    All existing content, including historical tags and releases, migrated to the new GitLab server. Once you switch over, you will not need to return to the old server.
  • Updated source_sync.sh Script
    We have updated the source_sync.sh script included with the Jetson BSP. The updated script started shipping with:
    • JetPack 7.1 GA
    • Jetpack 6.2.2 GA
    • IGX 2.0 GA
Impact to Developers
Developers who continue using older source_sync.sh versions or directly sync from nv-tegra after December 2026 will encounter sync failures. To avoid issues, please update your workflows to pull sources from the new GitLab location.
FAQs
  1. Why did the source server moved to GitLab?
    GitLab provides stronger tooling, better workflows, and a more scalable foundation for Jetson source distribution.
  2. Was any history lost during migration?
    No. All existing data, including historical tags and all prior releases were preserved and made available on GitLab.
  3. Do I need to update anything on my side?
    Yes, if you rely on older versions of source_sync.sh, or custom scripts pointing to nv-tegra.nvidia.com, you’ll need to update them to use the new GitLab paths.
  4. When do the old sync paths stop working?
    After December 2026, sync operations targeting nv-tegra.nvidia.com will fail.
  5. Which Jetson releases include the updated source_sync.sh?
    All latest releases starting with JetPack 7.1 GA, Jetpack 6.2.2 GA, IGX 2.0 GA include the updated script.
  6. What if I stay on an older JetPack release?
    You can continue using older releases, but you’ll need to manually update your sync URLs or source_sync.sh before December 2026. You can do that by manually replacing “nv-tegra.nvidia.com” with “gitlab.com/nvidia/nv-tegra” in the script.
  7. Do I need a GitLab account to access sources?
    No account will be required for public Jetson repositories. If authentication is required for certain components, we’ll publish details during the transition period.
  8. Will there be downtime during the migration?
    No, there is no downtime during the migration.
