Jetson Thor abnormal consecutive automatic reboots have occurred
When we power on our custom board equipped with Thor SOM, intermittent multiple consecutive automatic system reboots occur. This issue’s currently difficult to reproduce. Attached are the serial port logs documenting the entire process. From the logs, it can be observed that the UEFI prints the following error messages shortly after power-on.
Subsequently, the system immediately reboots upon attempting to enter the operating system. Through the serial port logs, we can trace the kernel-printed error messages recorded just before each reboot.
The system underwent 4 consecutive reboots before it finally booted into the operating system and stabilized. May we inquire if similar issues have been encountered previously?
reboot_several_time.txt (766.0 KB)
Hi xus,
Is this issue specific to your custom carrier board as I don’t see such issue on the AGX Thor devkit?
Do you have custom design in display or do you connect the display currently?
If so, please remove it and check if you can still reproduce the issue.
Jetpack version is 38.2.1.
Our design in display is as below. OK, I’ll try to reproduce with display removed.
Jetson Thor dual HDMI hotplug issue - Jetson & Embedded Systems / Jetson Thor - NVIDIA Developer Forums
