Jetson TX1 only shows NVIDIA logo then goes blank forever
I have been using my Jetson TX1 but today I shut it down, rebooted it and it only boots up to showing the NVIDIA logo then goes blank. I have unplugged are all peripheral devices like HDMI, keyboard and mouse but it still does not work. Why is this happening? Attached is screenshot of the error message it shows on the screen before it goes blank.
hello 191129120,
it should boots into linux kernel, are you able to login the target with ssh?
I cannot ssh since it does not boot successfully for me to see the IP its on.
hello 191129120,
could you please setup a serial console to gather the complete logs for reference?
BTW, is it possible to re-flash the target?
I’m downloading a new image to try reflashing it as it seems there is no other way out.
Downloaded a new image, formatted the SD card using the formatter and now Belinda Etcher has been become a problem. It keeps throwing the as show in the attached image.
hello 191129120,
why you’re using SD card, don’t you use TX1 which has internal eMMC?
