Hi. I was using Jetson TX2 with Jetpack 4.4.1, A serious error has occurred. If I install and use the jet pack and reboot when a reboot is required, the Ubuntu GUI fails to run and the screen below will stick out as the screen below is output.
<--------------------------error code-------------------------->
vdd-1v8: voltage operation not allowed
sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
I tried to reinstall the jet pack several times, but the problem was not solved. I need your help. Thank you.
