Hi All,
I tried to install the latest JetPack 4.2.2 on evaluation board(for Jetson TX2).
I managed to install it and even passed the initial setting screens and I was able to see the latest Ubuntu 18.04 running.
The problem occurred, when I rebooted the system (HW power down).
After that, I can see a several reboot cycles (over serial debug port)
As for example:
[0003.987] I> tegrabl_load_kernel_and_dtb: Done
[0003.997] I> Kernel EP: 0x80800000, DTB: 0x80000000
U-Boot 2016.07-gd917e08cec (Aug 12 2019 - 21:16:16 -0700)
And then again, the whole boot process prints.
Is this a normal behavior for TX2i?
Does someone managed to work with TX2i with latest JetPack?
Maybe I need to use a proprietary evaluation board for TX2i?
Thanks in advace
