I downloaded the latest Jetpack version 4.2.1 and ran the following command to flash my TX2 board:
sudo ./flash.sh jetson-tx2 mmcblk0p1
The flash process seems to be successful but the board does not boot properly. I see the following message on the debug UART:
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-922) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Tue Jul 16 17:09:53 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 2.955459] cgroup: cgroup2: unknown option “nsdelegate”
[ 4.569149] using random self ethernet address
[ 4.574132] using random host ethernet address
[ 4.605212] using random self ethernet address
[ 4.609979] using random host ethernet address
[ 4.898481] random: crng init done
[ 4.901890] random: 7 urandom warning(s) missed due to ratelimiting
[ 14.563775] Please complete system configuration setup on /dev/ttyGS0 to proceed…
[ 412.551900] tegra-xudc-new 3550000.xudc: setup request failed: -95
What do I need to do to get this to boot properly?
My host system is an ubuntu 16.04 VM, this worked fine for building the 3.2.1 jetpack.
