I’m designing a custom carrier board for the TX2, implementing the HDMI. I’ve got HDMI working, but only when I use the following command:
echo 1 > /sys/kernel/debug/tegra_hdmi/hotplug
Now I’ve seem to found the problem, our HPD isn’t inverting while the dev kit does have the HPD inverted. How do I go about change the behavior of this? The OEM design manual states the following:
Level shifters required on DDC/HPD. Jetson TX2/TX2i pads are not 5V tolerant & cannot directly meet HDMI VIL/VIH
requirements. HPD level shifter can be non-inverting or inverting.
Thus, I guess there should be a software solution to fix this problem?
Thanks for your answer, unfortunately changing ‘GPIO_ACTIVE_LOW’ to ‘GPIO_ACTIVE_HIGH’ didn’t do the trick. I’m using the same GPIO/HDMI combo as the NVIDIA devkit so I don’t need to change the GPIO and SOR. Also, changing it from low to high didn’t give any effect in behavior on the devkit itself, so I think it needs to be changed on more places…
Thank you very much @D3_cpetrescu! That was indeed the solution!
For future reference, I edited it to the following in /sources/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common/platforms/tegra186-quill-common.dtsi :
