Hey, i have a question regarding the micro ab USB2.0 Connector circuitry.
The USB OTG VBUS is implemented using APL3511 Load switch.
looking at the APL3511 data sheet:
the VOUT AMR is up to 7V. but when there is a plug or unplug even while there is current flowing through the cable itself, i can get inductive ringing that can cause the 5V line to temporarily go up to 10V which passes the load switch AMR.
Now for the TVS there, MSP5.0A-M3/89A, it clamps only to 9.2V.
also for the USB0_VBUS_DET pin of the jetson, when i power the jetson from 5.5-9.5V i can pass the amr which is VDD+0.5
So i don’t understand how it is okay, or maybe that case i mentioned is not so common? or maybe there is something else i’m missing…
