We have designed a custom carrier board for the jetson TX2 module.
we had a issue with the USB OTG not working as host.
after some research we got our problem solved by referring to this site
[url]Jetson/TX2 USB - eLinux.org
so we followed the steps given in the site and the OTG worked properly.
so my doubts are,
- what do you mean by GPIO regulators ?
- what changes do I need to do in my custom carrier board H/W design so that I don’t need to change the device tree.
in your TX2 adaptation guide(page 10), you have told to include vdd_usb2_5v supply to enable vbus-2-supply but I was not able to find the netnames anywhere in your schematics or any other document. so can you pls tell me what changes do I need to do in H/W so that we don’t need this device tree change
Regards,
R.Rohith yadav
Hi, the pin P00 of U29 is a enable pin for M.2 Key E in P2597 and that is needed to enable USB2_DP/DM on M.2 Key E. So is the name given usb2_5v.
Hi Trumany,
In our design we have used USB0 signals for the USB OTG,
but the below change makes it work,
- vbus-2-supply = <&vdd_usb2_5v>;
- vbus-2-supply = <&battery_reg>;
but this is for the USB2 signals, then why does it affect the USB0 singals.
Thanks,
R.Rohith yadav
Sw tries to configure the vbus-2 supply and it fails since the expander is not available.
So, to avoid sw to fail, vbus-2 is supplied with battery supply which is a fixed regulator with no constraints. SW happily enables this dummy regulator and proceed.
Hi Trumany,
I have some question regarding this,
- Why does changing the Vbus-2-supply (which is the enable for USB2 signals) affect the working of USB0 signals
- I don’t have the expander on my custom carrier board, so can I change something H/W wise in my board. so that the USB0 work on my custom carrier board without any device tree change.
Thanks,
R.Rohith yadav
