Greeting. I have Jetson Tx2 Developer Kit. I want to power it with portable powerbank, so I want to ask your opinion on suitable power setup. I am using Jetson TX2 dev kit with Zed2 camera, and running it for object detection using yolo v4, the wifi 2.4ghz is also being used. So I am expecting Jetson tX2 to be running at its maximum workload to handle all processes I mentioned. Also, the jetson is expected to be operating for ~40min per single charge,
I am quite new with electronic parts and power supply. I want to ask does this 2 option that I listed below is suitable and fit well with Jetson barrel jack. Feel free to add powerbank options (Amazon/Alibaba link) that requires less setting.
- 5V10000MAH Dual Voltage 5V / 12V Lipo
Specification:
Input Voltage:DC12.6V
Output Voltage:DC10.8-12.6V 4800mAh
USB Port Output Voltage:5V 10000mAh
Output Current:2A
- Baseus 22.5W/ 65W Power Bank 20000mAh Type C + Type C To DC 5.5 X 2.5mm PD Charging Cable
Specification:
Type C Output: 5V/3A, 9V/2A, 12V/1.5A Max
This option (no 2), I am thinking of connecting the powerbank with type C to barrel jack converter suitable with jetson power input socket.Not sure if it would work or not, need opinion.
Appreciate the helps, Thank you.
