Problem: I am trying to flash my JETSON TX2 from VMware workstation 14 player (running ubuntu 16.04) on my windows machine. I finally got the vm to recognize the board as a usb device upon booting in recovery mode. However, after I finished the instillation the log reported flashing was successful, but there aren’t any demos or programs on the board. The last thing that I was prompted with was determining device IP. I selected manual entry.
Log file:
Using rootfs directory of: /home/evan/Downloads/64_TX2/Linux_for_Tegra/rootfs
Extracting the NVIDIA user space components to /home/evan/Downloads/64_TX2/Linux_for_Tegra/rootfs
Extracting the BSP test tools to /home/evan/Downloads/64_TX2/Linux_for_Tegra/rootfs
Extracting the NVIDIA gst test applications to /home/evan/Downloads/64_TX2/Linux_for_Tegra/rootfs
Extracting the configuration files for the supplied root filesystem to /home/evan/Downloads/64_TX2/Linux_for_Tegra/rootfs
Creating a symbolic link nvgstplayer pointing to nvgstplayer-1.0
Creating a symbolic link nvgstcapture pointing to nvgstcapture-1.0
Extracting Weston to /home/evan/Downloads/64_TX2/Linux_for_Tegra/rootfs
Adding symlink libcuda.so → libcuda.so.1.1 in target rootfs
Adding symlink libGL.so → libGL.so.1 in target rootfs
Adding symlink libnvbuf_utils.so → libnvbuf_utils.so.1.0.0 in target rootfs
Adding symlink libnvid_mapper.so → libnvid_mapper.so.1.0.0 in target rootfs
Adding symlink libcuda.so → tegra/libcuda.so in target rootfs
Adding symlink libEGL.so → libEGL.so.1 in target rootfs
Adding symlink libGLESv2.so → libGLESv2.so.2 in target rootfs
Adding symlink /home/evan/Downloads/64_TX2/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libdrm_nvdc.so → /home/evan/Downloads/64_TX2/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/tegra/libdrm.so.2
Adding symlink nvidia_icd.json → /etc/vulkan/icd.d/nvidia_icd.json in target rootfs
Creating symlinks for weston, wayland-demos, libinput and wayland-ivi-extention modules
Adding symlinks for NVIDIA systemd services
Copying USB device mode filesystem image to /home/evan/Downloads/64_TX2/Linux_for_Tegra/rootfs
Disabling NetworkManager-wait-online.service
Disable the ondemand service by changing the runlevels to ‘K’
Extracting the firmwares and kernel modules to /home/evan/Downloads/64_TX2/Linux_for_Tegra/rootfs
Extracting the kernel headers to /home/evan/Downloads/64_TX2/Linux_for_Tegra/rootfs/usr/src
tar: write error
Adding symlink /home/evan/Downloads/64_TX2/Linux_for_Tegra/rootfs/lib/modules/4.4.38-tegra/build → /usr/src/linux-headers-4.4.38-tegra
Installing Image into /boot in target rootfs
Installing the board *.dtb files into /boot in target rootfs
Success!
I have no idea what to do next. I have attempted to complete the process through virtual box w/virtual box extenstions and failed. I deleted everything from the virtual box, attempted flashing and failed. Then I downloaded VM workstation and downloaded JETPACK, tried installing got the log shown above, but to no avail the board still doesn’t have the drivers or demos that I need. Any help would be greatly appreciated.
