Jetson TX2 NX boot up from external SD card
I would like to boot up Jetson TX2 NX from an external SD card .Is it possible to boot up Jetson TX2 NX from an external SD card?If yes could you please share me the steps to be followed?
Thanks in advance
You can refer to the usb method here but do the same thing to your sdcard.
Also, it is better to dump the serial console when doing this because you may need to interact with the uboot.
