I want to connect to the Jetson TX2 via Wifi to operate it via ssh. This works when I connect the Jetson to the available wifi at the lab. However, I want the Jetson to distribute its own hotspot to which I can connect with my laptop. I created the hotspot like so: wireless - How to create wifi hotspot in Ubuntu 16.04 since AP-Hotspot is no longer working - Ask Ubuntu I tried with several devices to connect to the hotspot. but all of them failed without any error message. Is this a known issue with the jetson. Creating such a hotspot on a laptop works fine.
Thank you and best regards
Please refer to https://devtalk.nvidia.com/default/topic/1038678/jetson-tx1/wifi-ap-mode-not-working-with-l4t-28-2-1/post/5277400/#5277400
Hey Wayne,
thanks for the answer. I have the same issue and with your advice it was possible to share the network and getting access to the TX2.
My question goes a little bit further: The Jetson has now a random IP adress, but i need to specify the IP-adress because the jetson is in another network with different components. Who can i specify IP Adresse, Netmask and Gateway in an Hotspot Wifi?
betznxqsv,
The ip address should be assigned by dhcp server.
1) Install isc-dhcp-server Install isc-dhcp-server (sudo apt install isc-dhcp-server)
2) Edit the file /etc/default/isc-dhcp-server and set INTERFACES like this:
INTERFACES="wlan0"
3) In /etc/dhcp/dhcpd.conf Find below lines and put # before it. It should look like after editing
# option definitions common to all supported networks…
#option domain-name “example.org”;
#option domain-name-servers ns1.example.org, ns2.example.org;
4) Again comment out following lines too
#default-lease-time 600;
#max-lease-time 7200;
5) Add following lines at end
subnet 10.10.0.0 netmask 255.255.255.0 {
range 10.10.0.2 10.10.0.16;
option domain-name-servers 8.8.4.4, 208.67.222.222;
option routers 10.10.0.1;
6)In /etc/network/interfaces, Add below
auto wlan0
iface wlan0 inet static
address 10.10.0.1
wlan0 is your wireless interface. Change it accordingly.
