Hello I am Jetson Tx2 for development. I have used the ethernet and create a static network to connect with the Jetson from my host PC using SSH.
I have to connect with Jetson board Wifi from my host PC, but unable to find its SSID on my network panel. Is there any way to connect with onboard WIFI of jetson? So i will connect with Jetson TX2 wifi and then SSH it. Any setup to follow?
I also saw that the wifi and bluetooth are enabled by default.
