I’ll try and update
disabling the “problematic” pcie node in the UEFI device tree allows the system to boot but it remains disabled after kernel is loaded as well. It has the same result as disabling the “problematic” pcie node in the kernel dtb.
I thought that disabling it in the UEFI dtb and enabling it in the kernel dtb will allow it to work properly after bypass the UEFI issue.
Is there something else I can try?
Then I think you are actually not doing it right…
