So I just got my Xavier in today and when I try to connect to it with my host Ubuntu machine, it never sees the Xavier. I have tried flashing it several times but it can never do it over the usb. I’m stuck now and I don’t know what to do next. Is there something I’m missing? The only thing I can think of that I did wrong was starting the Xavier up before hooking it up to a host. I only figured that part out after the fact.
Do you mean you can put Xavier into recovery, and flash it successfully.
But when boot it up. You can’t make it as a USB device, while want your X86 PC act as USB host?
I think your system and usb port is good.
But you should use the other USB type-C port nearby the LED.
You will see a L4T-README otg drive.
And there will be document to tell you how to use the USB as virtual ethernet/UART/Storage.
Thanks for the reply. I actually managed to get this all working successfully about an hour ago. I looked through the logs and saw a Python error. It seemed like it was unable to locate Python2 on my host. I installed Python2 and then tried again. It made a connection and started flashing right away. Very strange that they would not do a pre-check for something as crucial to the install as this.
