Hello
I know i can Install LabVIEW on Ubuntu 18.04.
So i Would like to know if it possible to install it on the Jetson AGX Xavier ?
Thanks you
I can’t answer this, you can do the search in forum or check with LabVIEW to know if it can support on arm64 Linux device?
I’ll also add that if LabVIEW has arm64
, but uses a GPU, then it might detect the GPU via PCI functions (nvidia-smi
), in which case it won’t work (the integrated GPU of a Jetson does not work with PCI functions since it integrates directly with the memory controller).
