I use the Xavier NX devkit and 16GB module do reboot stress testing. During testing, I encountered four booting failures.
The first time happens after reboot 400 times.
The second time happens after reboot 150 times.
The third time happens after 200 times.
The fourth time happens after 50 times.
Reboot failures seem inevitable happen. After reboot failures, I need to reconnect the power and then I can reboot it successfully. I want to ask is my failure probability normal? I have to make sure my product is reliable during use. Is there any way I can avoid reboot failures. Thanks!
I used devkit board and devkit module, 4core 10W mode. But when I try 6core 15W mode . This reboot failure will not happen again.
I only have this log file. Is it enough? The devkit are not here now. Recollect new full log will speed some times. 20220516.log (10.7 MB)
Yes, We have devkit board, devkit module, 8G emmc module, 16GB emmc module and custom board. We try many combination of module and board under 4core 10W mode. Reboot failure is inevitable.
