We flashed our Jetson Xavier NX by SDK Manager on HOST PC, then moved NX module to Carrier Board, and the OS be booted normally.
On My Carrier Board 4 USB ports are designed ,but only 2 ones work, the other 2 ones have no power. And 2 RJ45 ports, only 1 RJ45 works. When I run lspci on shell, nothing is displayed.
Could someone give me some indication about these problems? hardware or dtb etc.
Hi, it is hard to tell if no detail info. Did you follow the design guide and reference schematic for custom design? Did you configure the pinmux sheet based on your design? What’s the difference between your design and dev kit? Please share more information about above.
