Hello.
I use Jetson Xavier NX Developkit(8GB) right now. I found out increase used memory(RAM) at NX Devkit. The NX Devkit just write Jetpack4.4 image to SD card and connect a monitor/keybord, do initial setting , run command “$ free”. And wait for a while, I run command “$ free” again. Then I confirmed increase 20MB on used memory(RAM). I tried other NX and SD cards, but similar result. (I tested for 48 hours, then confirmed increase 400MB on used memory.)
Is this happened because of Devkit? Or did I wrong something? Please tell me solution.
For your information, I have plan to use Jetson Xavier NX(Product). So if don’t happen on Product version, I don’t care that.
We haven’t experiences that issue from other developers, please try with the latest JetPack 4.6 again.
Thanks replay kayccc,
I thought that… I can’t find similar document.
Actuary I did try JetPack 4.6 in NX(Developkit). Then I confirmed to happen same thing.
The data listed below.(Mem:used value)
[date], [time(hh:mm)], [used Mem value]
2/8 , 03:58 , 1784592
2/8 , 19:51 , 1993492
2/10 , 03:28 , 2263156
2/14 , 19:25 , 2992624
BTW, Jetson TX2 Products don’t happen that.
Is there bad combination about SD card? I use what HIDISC Corp release.
Do you have any process running over the background?
Thanks WayneWWW,
Yes. Something like “Xorg” and “systemed” etc. If you would like to confirm detail, I will write output result!
Intentional running is only “$ free” command.
Did you always put device in idle state or you have done some suspend/resume?
Yes, I always put device, a keyboard and a monitor.
As a side note, I set Blank Screen → “Never”. Sorry I forgot to say.
Yes, I always put device in idle state a few weeks.
We can’t reproduce issue with r32.6.1/NX-SD card image as yours
Test 16 hours, the mem used start from 1447896 → 1479104 end.
Thanks you for testing.
We never connect display, then memory used start from 572272 → 576700 end.(10 hours)
So I close this question. Thanks for all.
Thanks for your update.
