I created a custom carrier board for jetson xavier. In that i added one USB 2.0 HUB. So can i take one USB 2.0 Pair from HUB and other RX and TX connections directly from Jetson and make a USB 3.0 Port?
No, this design is wrong. USB2 must come out from Xavier itself.
Can you explain why.
To my knowledge if the downstream device is USB3.0 then there is no need for D+ and D-. So this should work, right?
If the device connected is not USB 3 then only it will do the handshake through D+ and D-.
Jetson driver cannot control the USB behavior behind your hub.
