USB3 HUB connected to the JETSON XAVIER NX
I am using USB3 HUB from microchip instead of the HUB used by NVIDIA in the original carier evb.
for the upstream I use the usb2 + usb 3 and the downstream consumers are 2 cameras, single BARCODE reader and another USB2 hub 1->2.
I am wondering if there are some limitations and if the design I made is correct.
Can you help me with it?
Hi, for USB part design of NX, as said in OEM product DG, there is example design there. For NX, only one USB3.1 port + 3 USB2.0 ports for your option, you can make design of NX side based on that. As for the design of third-part HUB side, we have no idea of review help, you can check with vendor for the design help.
