- Does the Xavier NX “JPEG Processing Block” support JPEG 2000 encoding?
- Is there any way to losslessly encode still-frames through the GPU or any non-CPU hardware? It seems
nvjpegenc
supports only JPEG.
Thank you.
nvjpegenc
supports only JPEG.Thank you.
AFAIK, JPEG2000 encoding is only available from CPU on Jetson. See: JPEG2000 library for Jetson Nano - #4 by Honey_Patouceul
nvjpegenc only supports JPEG, but you can try setting quality to max (100) and see if this suits your needs:
gst-launch-1.0 videotestsrc num-buffers=1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=I420' ! nvjpegenc quality=100 ! filesink location=test.jpg
