We are deploying a Greengrass v2 component formed by 2 python scripts. One of them uses jtop python module to read different values from hardware, for example CPU or GPU temperatures.
This is the Greengrass component recipe we are using:
"RecipeFormatVersion": "2020-01-25",
"ComponentName": "com.example.HelloWorld",
"ComponentVersion": "1.1.2",
"ComponentType": "aws.greengrass.generic",
"ComponentDescription": "My first AWS IoT Greengrass component.",
"ComponentPublisher": "Amazon",
"ComponentConfiguration": {
"DefaultConfiguration": {
"Message": ""
"Manifests": [
"Platform": {
"os": "linux"
"Name": "Linux",
"Lifecycle": {
"Run": "python3 {artifacts:path}/aws_jetson_reporte_estado.py"
"Artifacts": [
"Uri": "s3://pruebagreengrass/aws_jetson_reporte_estado.py",
"Digest": "",
"Algorithm": "SHA-256",
"Unarchive": "NONE",
"Permission": {
"Read": "OWNER",
"Execute": "NONE"
"Uri": "s3://pruebagreengrass/utils.py",
"Digest": "",
"Permission": {
"Read": "OWNER",
"Execute": "NONE"
"Lifecycle": {}
However, when we deploy Greengrass component into the Jetson we get an error related to jtop:
[WARN] (Copier) com.example.HelloWorld: stderr. raise JtopException(“I can’t access to jetson_stats.service.\nPlease logout or reboot this board.”). {scriptName=services.com.example.HelloWorld.lifecycle.Run, serviceName=com.example.HelloWorld, currentState=RUNNING}
[WARN] (Copier) com.example.HelloWorld: stderr. jtop.core.exceptions.JtopException: I can’t access to jetson_stats.service… {scriptName=services.com.example.HelloWorld.lifecycle.Run, serviceName=com.example.HelloWorld, currentState=RUNNING}
[WARN] (Copier) com.example.HelloWorld: stderr. Please logout or reboot this board… {scriptName=services.com.example.HelloWorld.lifecycle.Run, serviceName=com.example.HelloWorld, currentState=RUNNING}
Do you know what is causing the problem or how to solve it?
Thanks in advanced.
