Operating System:
Windows
Linux
Kit Version:
110 .2.0 (Kit App Template)
Kit Template:
USD Composer
GPU Hardware:
30 series
GPU Driver:
Recommended (573.xx)
Work Flow:
Activating warp menu is causing the whole Omniverse menu to be disabled.
additionally the kit file within source> apps> *.kit also has the below setting by default.
“omni.warp”.enable_menu = false
Main Issue:
Reproduction Steps:
refer the attached video ..
- Build a new composer app ,
- Search for > "Warp Menu " from Extension
- Enable the Warp menu
- causes the whole omniverse menu disabled.
Error Code:
[ ext: omni.warp.menu-1.0.0 ] Failed to startup python extension.
AttributeError: ‘tuple’ object has no attribute ‘copy’
