The extension omni.kit.xr.profile.vr got replaced with omni.kit.xr.system.openxr (or so I assume). The issue with this new extension is that it does not have a way to toggle its window. If you enable the extension and close its window/widget, there is no way to re-opening it back up. This is even worse when you have a default layout on a custom application. Unless you manually add the extension’s window name to the layout, good luck opening the window.
Am I missing something? The old omni.kit.xr.profile.vr had a menu under Window → Rendering.
