Kit-cae user samples are missing from link provided in user guide Kit-CAE Sample: User Guide — Kit CAE User Guide
We are sorry for the inconvenience. We have recently updated this whole section over on GitHub. Please follow it here for all of the new source code
GitHub - NVIDIA-Omniverse/kit-cae: Omniverse Kit sample for CAE use-cases
Dear Richard,
Thank you. Understand, Yes I noticed the user guide section was then lately updated.
However the issue of downloading the sample files still persist as I checked again now from the link that you shared : -
Are you able to download the samples mentioned in the user guide section ?
As a quick fix if alternate mirrors site can be provided to download samples that will be of great help.
Link to samples files from userguide : https://d4i3qtqj3r0z5.cloudfront.net/CAE_UserGuideSamples_NVD%4010010.zip
File name should be : xxxxxxz_NVD@10010.zip
Cheers,
-Preetham Pai N
No, that is not the place you are downloading from. Like I said, please discard that whole page and link. Download from here the Github page. It works I just downloaded it
https://codeload.github.com/NVIDIA-Omniverse/kit-cae/zip/refs/heads/main
Richard, the kit_cae per se works for me like charm.
There are a few samples files that are not included in this git_repository but are needed to practice steps from the user guide section.
Can you please double check " if your are able to download the sample files described in the user guide section of Kit-cae "
I ve posted clear snapshot of error resposne from the hyperlink embedded in user guide section of kit_cae..
Cheers,
-Preetham Pai N
Any luck downloading user sample files ?
Cheers,
-Preetham Pai N
If you try the link now, is is working again. Sorry for the inconvenience
Richard, Thanks . [“maybe” your VPN authenticates the external link, doesnt work outside of the Nvidia network]
Suggest if you could provide an alternate mirror repository to download the files “for now” and later move the files to this section.
Strange. It definitely works worldwide without vpn. I just ran a ping on it and downloaded it on a fresh machine. I am not on VPN. Can you force refresh the page and the link? We just fixed it today. Maybe your area is slow to propagate the change. What part of the world are you in?
Here is a video of it downloading on an open connection.
i think it slowly trickled down to our Zone .. may be to do with the hyperlink
Finally
with and without hyperlink
Solution : - use https://d4i3qtqj3r0z5.cloudfront.net/CAE_UserGuideSamples_NVD@10010.zip
Thanks @Richard3D for your Support !
