I successfully built and installed Librealsense (last version : 2.36.0) with python bindings on last Jetpack version, but when trying to use it with python I have this :
AttributeError: module ‘librealsense’ has no attribute ‘config’
To install it I used theses steps :
Installing some prerequisite :
sudo apt-get install libglfw3-dev libgl1-mesa-dev libglu1-mesa-dev
sudo apt-get install git libssl-dev libusb-1.0-0-dev pkg-config libgtk-3-dev
installing curl
wget http://curl.haxx.se/download/curl-7.71.1.tar.bz2
tar -xvjf curl-7.71.1.tar.bz2
cd curl-7.71.1
./configure --with-nghttp2=/usr/local --with-ssl
make
sudo make install
sudo ldconfig
Updating cmake with version 3.13 (needed to build librealsense on last jetpack version) :
wget http://www.cmake.org/files/v3.13/cmake-3.13.0.tar.gz
tar xpvf cmake-3.13.0.tar.gz cmake-3.13.0/
cd cmake-3.13.0/
./bootstrap --system-curl
make -j6
echo ‘export PATH=/home/nvidia/cmake-3.13.0/bin/:$PATH’ >> ~/.bashrc
source ~/.bashrc
Installing Librealsense with python3 :
cd && git clone GitHub - IntelRealSense/librealsense: Intel® RealSense™ SDK
cd librealsense
mkdir build && cd build
cmake …/ -DBUILD_PYTHON_BINDINGS:bool=true -DFORCE_RSUSB_BACKEND=ON -DPYTHON_EXECUTABLE=/usr/bin/python3 -DCMAKE_BUILD_TYPE=release -DBUILD_EXAMPLES=true -DBUILD_GRAPHICAL_EXAMPLES=true
sudo make -j6
sudo make install
cd ~/librealsense
./scripts/setup_udev_rules.sh
export PYTHONPATH=$PYTHONPATH:/usr/local/lib
Any idea of what is wrong ? Could anyone install Librealsense with pyrealsense on last Jetpack version ?
