Hello I am trying to install the Nvidia License server on a Ubuntu 16.04 64-bit machine with no success. I already installed Java and Tomcat. Tomcat is running. I get the following information o the service:
flexnetls-nvidia.service - LSB: start and stop FlexNet License Server
Loaded: loaded (/etc/init.d/flexnetls-nvidia; bad; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2016-11-25 13:55:31 CST; 1min 48s ago
Docs: man:systemd-sysv-generator(8)
Process: 3087 ExecStart=/etc/init.d/flexnetls-nvidia start (code=exited, status=127)
Nov 25 13:54:30 UbuntuLicenseServer systemd[1]: Starting LSB: start and stop FlexNet License Server...
Nov 25 13:54:30 UbuntuLicenseServer flexnetls-nvidia[3087]: /etc/init.d/flexnetls-nvidia: line 656: /etc/init.d/functions: No such file or dir
Nov 25 13:54:31 UbuntuLicenseServer flexnetls-nvidia[3087]: /etc/init.d/flexnetls-nvidia: line 421: daemon: command not found
Nov 25 13:54:31 UbuntuLicenseServer flexnetls-nvidia[3087]: Waiting for server to start up...
Nov 25 13:55:31 UbuntuLicenseServer flexnetls-nvidia[3087]: Service not started yet - slow startup?
Nov 25 13:55:31 UbuntuLicenseServer systemd[1]: flexnetls-nvidia.service: Control process exited, code=exited status=127
Nov 25 13:55:31 UbuntuLicenseServer systemd[1]: Failed to start LSB: start and stop FlexNet License Server.
Nov 25 13:55:31 UbuntuLicenseServer systemd[1]: flexnetls-nvidia.service: Unit entered failed state.
Nov 25 13:55:31 UbuntuLicenseServer systemd[1]: flexnetls-nvidia.service: Failed with result 'exit-code'.
Update1:
Maybe Ubuntu is not the right server OS?
Thank you in advance.
