The vGPU license server used to have a settings that allowed a client to be deleted (marked as destroyed) from it’s details page - in order to free up a stale license. The license server I installed last evening doesn’t have that setting option. Has it been deprecated? Why? How else are we supposed to free up stale licenses, rather than waiting possibly days for the system to release them?
Hi forbsy,
thanks for raising this topic. I’m waiting for a response from PM. In the meantime I would suggest to reduce the lease time on the clients to free up licenses:
https://docs.nvidia.com/grid/latest/grid-licensing-user-guide/index.html#windows-registry-grid-license-settings
See LicenseInterval Key…
Regards
Simon
Hi forbsy,
this feature was removed from 3rd party vendor Flexera. So there is not much we can do atm.
Regards
Simon
The NVIDIA tech support gave me a solution to getting my licenses back. It’s not elegant, but it worked. Essentially your rebuilding you license server. I had all my vm’s shutdown and restarted after I had rebuilt the license server.
Hello Gary,
You’re correct, the license lease will time out after default 7 days.
You may clear Trusted Storage with following steps:
To Clear Trusted Storage
Log into NVIDIA Licensing Portal: https://nvid.nvidia.com/dashboard/#/dashboard
Click on Search License Servers and select the appropriate registered server
Click on Remove Add-Ons in the NVIDIA Licensing Portal
Enter number of Currently on Device in Quantity to Remove and click Remove Add-Ons
Close all browsers that are running on the license server
Go into the Microsoft Control Panel, Administrative Tools and Services
Locate the “FlexNet License Server – nvidia” service, right click on it and select Stop
Delete the nvidia folder from:
C:\Windows\ServiceProfiles\NetworkService\flexnetls\ -
Locate the “FlexNet License Server – nvidia” service. right click on it and select Start
Register the MAC address in the NVIDIA Software License Portal if applicable
Click on Search License Servers and select the registered server
Click on Download License File, save it to a local drive, then discard it (see note)
Click on Map Add-Ons from the NVIDIA Licensing Portal
Enter number of Add-Ons you want mapped in Qty to Add box and click on Map Add-Ons
Click Download License File
Save license bin file to disk and upload to local license server within 24 hours
Note: Step 13 is required to clear server information from the NVIDIA License Portal
Kind regards,
Aleksandar
NVIDIA Enterprise Support Team
