I have been interested in developing a cpu driven cicd pipeline for custom extensions. I have seen significant progress and am able to run pipelines both locally (Windows), and in CICD (linux). The linux pipeline is a modification of the kit-104 container ( test scripts, kit file, rootless folder structure, etc.) . This sufficed until I needed to add other extensions as a dependency.
The odd part is it windows works… for the most part.
By adding the following lines into my .kit file
[settings.app.exts]
folders.“++” = [
“git://github.com/NVIDIA-Omniverse/kit-extension-sample-ui-scene?branch=main&dir=exts”,
I am able to, 90% of the time pull down any git dependency (slightly modified).
Windows Success LOG
2023-06-21 15:46:50 [280ms] [Info] [omni.ext.plugin] [ext: omni.kit.extpath.git-0.0.0] applying settings
2023-06-21 15:46:50 [417ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.kit.app.plugin; not changing unload order
2023-06-21 15:46:50 [417ms] [Info] [omni.ext._impl._internal] Adding c:...\MY_AWESOME_EXTENSION\app\kit\extscore\omni.kit.extpath.git to sys.path
2023-06-21 15:46:50 [417ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.extpath.git-0.0.0] (order: -1000) Triggered by API/CLI/Config. (path: c:/…/MY_AWESOME_EXTENSION/app/kit/extscore/omni.kit.extpath.git)
2023-06-21 15:46:50 [417ms] [Info] [omni.kit.app._impl] python GC: gc.disable()
2023-06-21 15:46:50 [417ms] [Info] [omni.kit.app.plugin] [0.517s] [ext: omni.kit.extpath.git-0.0.0] startup
2023-06-21 15:46:50 [425ms] [Info] [omni.ext._impl._internal] Searching for classes derived from ‘omni.ext.IExt’ in ‘omni.kit.extpath.git’ (‘c:\users...\MY_AWESOME_EXTENSION\app\kit\extscore\omni.kit.extpath.git’)
2023-06-21 15:46:50 [426ms] [Info] [omni.ext._impl._internal] Found class ExtPathGitExt derived from omni.ext.IExt in module: ‘omni.kit.extpath.git’ in ‘c:…\MY_AWESOME_EXTENSION\app\kit\extscore\omni.kit.extpath.git’. Calling on_startup.
2023-06-21 15:46:50 [426ms] [Info] [omni.kit.extpath.git.utils] [omni.kit.extpath.git]: run process: [‘git’, ‘–version’]
2023-06-21 15:46:50 [498ms] [Info] [omni.ext.plugin] Registered protocol provider for scheme: git
2023-06-21 15:46:50 [498ms] [Info] [omni.ext.plugin] Registered protocol provider for scheme: git+https
2023-06-21 15:46:50 [498ms] [Info] [omni.ext.plugin] Registered protocol provider for scheme: git+ssh
2023-06-21 15:46:50 [498ms] [Info] [omni.ext.plugin] [ext: omni.kit.extpath.git-0.0.0] started, startup time: 80 (ms)
2023-06-21 15:46:50 [498ms] [Info] [omni.kit.extpath.git.utils] [omni.kit.extpath.git]: ExtPathGitExt::_on_add_path: git:/github.com/NVIDIA-Omniverse/kit-extension-sample-ui-scene?branch=main&dir=exts
2023-06-21 15:46:50 [499ms] [Info] [omni.kit.app._impl] [py stdout]: hello git:/github.com/NVIDIA-Omniverse/kit-extension-sample-ui-scene?branch=main&dir=exts, C:/Users/…/AppData/Local/ov/cache/gitexts
However, when making a new modification to the …/app/kit/extscore/omni.kit.extpath.git file, I am able to manually trigger an error similarly to what I see every run on the linux side.
Linux Fail LOG
2023-06-22 18:36:34 [91ms] [Info] [omni.ext.plugin] [ext: omni.usd.libs-1.0.0] registered (path: /opt/nvidia/omniverse/kit-sdk-launcher/extscore/omni.usd.libs)
2023-06-22 18:36:34 [91ms] [Info] [omni.ext.plugin] Extensions dependency solver solution:
[ext: omni.kit.extpath.git-0.0.0] no deps
2023-06-22 18:36:34 [91ms] [Info] [omni.ext.plugin] [ext: omni.kit.extpath.git-0.0.0] applying settings
2023-06-22 18:36:34 [91ms] [Info] [carb] Initializing plugin: carb.scripting-python.plugin (interfaces: [carb::scripting::IScripting v1.0]) (impl: carb.scripting-python.plugin)
2023-06-22 18:36:34 [92ms] [Info] [carb.scripting-python.plugin] Attempting to initialize Python interpreter. Failure of doing it will lead to the termination of the application.
2023-06-22 18:36:34 [128ms] [Info] [carb.scripting-python.plugin] Python interpreter was successfully initialized.
2023-06-22 18:36:34 [128ms] [Error] [carb.scripting-python.plugin] ModuleNotFoundError: No module named ‘omni’
At:
PythonExtension.cpp::prestartup()(1):
2023-06-22 18:36:34 [128ms] [Error] [omni.ext.plugin] [ext: omni.kit.extpath.git-0.0.0] Failed to process python module extension in ‘/opt/nvidia/omniverse/kit-sdk-launcher/extscore/omni.kit.extpath.git/.’.
2023-06-22 18:36:34 [128ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.extpath.git-0.0.0] (order: -1000) Triggered by API/CLI/Config. (path: /opt/nvidia/omniverse/kit-sdk-launcher/extscore/omni.kit.extpath.git)
2023-06-22 18:36:34 [128ms] [Info] [omni.kit.app.plugin] [0.154s] [ext: omni.kit.extpath.git-0.0.0] startup
At:
PythonExtension.cpp::shutdown()(1):
2023-06-22 18:36:34 [128ms] [Error] [omni.ext.plugin] Failed while calling shutdown_extensions function: /opt/nvidia/omniverse/kit-sdk-launcher/extscore/omni.kit.extpath.git
2023-06-22 18:36:34 [128ms] [Info] [omni.ext.plugin] [ext: omni.kit.extpath.git-0.0.0] started, startup time: 0 (ms)
2023-06-22 18:36:34 [128ms] [Error] [omni.ext.plugin] Failed to add extension path: ‘git:/github.com/NVIDIA-Omniverse/kit-extension-sample-ui-scene?branch=main&dir=exts’. Local path is empty or scheme is not supported.
2023-06-22 18:36:34 [363ms] [Info] [omni.kit.app._impl] python GC: gc.disable()
2023-06-22 18:36:34 [363ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.kit.app.plugin; not changing unload order
I added some logging to the extension itself, but I believe the issue to be a unix specific race condition. I have tried playing with the load order and adding dependencies to no avail.
Additionally, I have been looking at task manager for performance clues and on this fail it seemed to touch 100% CPU usage, memory looks fine at about 50%)
Does anyone have insights? Perhaps the git code has an undocumented dependency? Let me know if i can provide additional information.
