Trouble installing Modulus extension [Ubuntu 22.04 LTS]
Hi I’m trying to install the modulus extension
my system is Ubuntu 22.04 LTS, 11th Gen Intel® Core™ i7-11850H @ 2.50GHz × 16, NVIDIA Corporation GA104GLM [RTX A5000 Mobile] / Mesa Intel® UHD.
i ran Create 2022.1.3 from terminal window using ~/.local/share/ov/pkg/create-2022.1.3/omni.create.sh
the installation of the extension kicks up the network adapter then nothing happens after a while:
i’ve also navigated to /tmp and don’t actually see the zip file appearing (hidden files revealed with Ctrl+H)
this is my terminal log:
Loading user config located at: ‘/home/samson/.local/share/ov/data/Kit/Create.Next/2022.1/user.config.json’
[Info] [carb] Logging to file: /home/samson/.nvidia-omniverse/logs/Kit/Create.Next/2022.1/kit_20220614_103227.log
[0.142s] [ext: omni.stats-0.0.0] startup
[0.156s] [ext: omni.gpu_foundation-0.0.0] startup
2022-06-14 02:32:27 [137ms] [Warning] [carb] FrameworkImpl::setDefaultPlugin(client: omni.gpu_foundation_factory.plugin, desc : [carb::graphics::Graphics v2.5], plugin : carb.graphics-vulkan.plugin) failed. Plugin selection is locked, because the interface was previously acquired by:
[0.159s] [ext: carb.windowing.plugins-1.0.0] startup
[0.164s] [ext: omni.assets.plugins-0.0.0] startup
[0.165s] [ext: omni.kit.renderer.init-0.0.0] startup
MESA-INTEL: warning: Performance support disabled, consider sysctl dev.i915.perf_stream_paranoid=0
| Driver Version: 510.73.5 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | Intel(R) UHD Graphics (TGL GT1) | | | 47984 MB | 8086 | 0 |
| | | | | | 9a60 | 60e01855… |
| 1 | NVIDIA RTX A5000 Laptop GPU | Yes: 0 | | 16384 MB | 10de | 0 |
| | | | | | 24b6 | f88a3084… |
| OS: Linux samson-HP-ZBook-Fury-15-6-inch-G8-Mobile-Workstation-PC, Version: 5.15.0-37-generic
| Processor: 11th Gen Intel(R) Core™ i7-11850H @ 2.50GHz | Cores: Unknown | Logical: 16
| Total Memory (MB): 63979 | Free Memory: 60354
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
2022-06-14 02:32:29 [2,229ms] [Warning] [gpu.foundation.plugin] Disabling OpenGL Interop. Device 0 mismatched with OpenGL device: Mesa Intel(R) UHD Graphics (TGL GT1).
OpenGL can only run on the main GPU. It requires the app to run with activeDevice setting set to that GPU. On laptops, you may also need to specify which GPU or driver to run on in your system (Integrated or Discrete).
2022-06-14 02:32:29 [2,230ms] [Warning] [gpu.foundation.plugin] Realm: no OpenGL interop context.
2022-06-14 02:32:29 [2,283ms] [Warning] [carb.cudainterop.plugin] On Linux only, CUDA and the display driver does not support IOMMU-enabled bare-metal PCIe peer to peer memory copy.
However, CUDA and the display driver does support IOMMU via VM pass through. As a consequence, users on Linux,
when running on a native bare metal system, should disable the IOMMU. The IOMMU should be enabled and the VFIO driver
be used as a PCIe pass through for virtual machines.
[2.312s] [ext: omni.kit.window.splash-0.0.0] startup
[2.328s] [ext: omni.kit.async_engine-0.0.0] startup
[2.339s] [ext: omni.kit.agent-0.1.0] startup
[2.340s] [ext: omni.kit.splash-0.2.1] startup
[2.349s] [ext: omni.kit.pipapi-0.0.0] startup
[2.351s] [ext: omni.usd.config-1.0.0] startup
[2.351s] [ext: omni.usd.libs-1.0.0] startup
[2.493s] [ext: omni.kit.pip_archive-0.0.0] startup
[2.496s] [ext: omni.usd.schema.semantics-0.0.0] startup
[2.531s] [ext: omni.usd.schema.audio-0.0.0] startup
[2.536s] [ext: omni.hydra.iray-0.1.0] startup
[2.542s] [ext: omni.kit.telemetry-0.1.0] startup
[3.921s] [ext: omni.services.pip_archive-0.4.0] startup
[3.924s] [ext: omni.kit.loop-default-0.1.1] startup
[3.924s] [ext: omni.appwindow-1.0.0] startup
[3.927s] [ext: omni.client-0.1.0] startup
[3.933s] [ext: omni.kit.test-0.0.0] startup
[3.959s] [ext: omni.kit.renderer.core-0.0.0] startup
[4.124s] [ext: omni.ui-2.10.3] startup
[4.135s] [ext: carb.audio-0.1.0] startup
[4.159s] [ext: omni.kit.mainwindow-0.0.0] startup
[4.161s] [ext: omni.uiaudio-1.0.0] startup
[4.162s] [ext: omni.kit.uiapp-0.0.0] startup
[4.162s] [ext: omni.usd.schema.physics-1.0.0] startup
[4.170s] [ext: omni.usd.schema.anim-0.0.0] startup
[4.199s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[4.205s] [ext: omni.timeline-1.0.2] startup
[4.206s] [ext: omni.hydra.scene_delegate-0.2.0] startup
[4.211s] [ext: omni.kit.commands-1.2.2] startup
[4.213s] [ext: omni.kit.audiodeviceenum-1.0.0] startup
[4.214s] [ext: omni.usd-1.5.3] startup
[4.596s] [ext: omni.kit.asset_converter-1.2.30] startup
[4.610s] [ext: omni.usd.schema.forcefield-0.0.0] startup
[4.616s] [ext: omni.usd.fileformat.e57-0.1.6] startup
[4.616s] [ext: omni.usd.schema.sequence-2.0.11] startup
[4.623s] [ext: omni.usd.schema.destruction-0.2.1] startup
[4.628s] [ext: omni.usd.fileformat.sbsar-0.8.0] startup
[4.654s] [ext: omni.usd.schema.physx-0.0.0] startup
[4.674s] [ext: omni.services.transport.client.base-1.2.0] startup
[4.675s] [ext: omni.services.facilities.base-1.0.2] startup
[4.676s] [ext: omni.kit.widget.path_field-2.0.3] startup
[4.678s] [ext: omni.services.core-1.2.0] startup
[4.760s] [ext: omni.kit.search_core-1.0.2] startup
[4.761s] [ext: omni.services.client-0.3.0] startup
[4.762s] [ext: omni.services.transport.server.base-1.0.2] startup
[4.762s] [ext: omni.kit.widget.versioning-1.3.8] startup
[4.764s] [ext: omni.kit.widget.browser_bar-2.0.3] startup
[4.765s] [ext: omni.kit.widget.filebrowser-2.2.26] startup
[4.768s] [ext: omni.services.transport.client.http_async-1.2.1] startup
[4.768s] [ext: omni.services.transport.server.http-1.1.2] startup
[4.779s] [ext: omni.kit.notification_manager-1.0.5] startup
[4.781s] [ext: omni.kit.window.popup_dialog-2.0.7] startup
[4.783s] [ext: omni.kit.thumbnails.images-0.2.3] startup
[4.825s] [ext: omni.mdl.neuraylib-0.1.0] startup
[4.827s] [ext: omni.kit.window.filepicker-2.4.29] startup
UsdE57FileFormat
OmniAssetFileFormat
[4.871s] [ext: omni.mdl-0.1.0] startup
[4.884s] [ext: omni.kit.window.file_importer-1.0.4] startup
[4.885s] [ext: omni.kit.menu.utils-1.2.11] startup
[4.891s] [ext: omni.kit.stage_templates-1.1.2] startup
[4.892s] [ext: omni.kit.material.library-1.3.10] startup
[4.894s] [ext: omni.kit.window.file_exporter-1.0.4] startup
[4.895s] [ext: omni.kit.menu.create-1.0.2] startup
[4.895s] [ext: omni.kit.window.file-1.3.16] startup
[4.897s] [ext: omni.kit.window.drop_support-1.0.0] startup
[4.897s] [ext: omni.kit.context_menu-1.3.9] startup
[4.899s] [ext: omni.kit.window.content_browser-2.4.28] startup
[4.912s] [ext: omni.kit.window.property-1.6.3] startup
[4.913s] [ext: omni.kit.widget.graph-1.4.2] startup
[4.915s] [ext: omni.kit.widget.stage-2.6.15] startup
[4.918s] [ext: omni.kit.widget.prompt-1.0.1] startup
[4.918s] [ext: omni.kit.property.usd-3.14.8] startup
[4.941s] [ext: omni.hydra.engine.stats-1.0.0] startup
[4.949s] [ext: omni.kit.viewport.legacy_gizmos-1.0.0] startup
[4.952s] [ext: omni.hydra.pxr-1.1.0] startup
[4.954s] [ext: omni.graph.tools-1.3.5] startup
[5.045s] [ext: omni.renderer-rtx-0.0.0] startup
[5.046s] [ext: omni.hydra.rtx-0.1.0] startup
[5.051s] [ext: omni.debugdraw-0.1.0] startup
[5.056s] [ext: omni.graph.core-2.27.1] startup
[5.062s] [ext: omni.kit.widget.settings-1.0.0] startup
[5.066s] [ext: omni.graph-1.22.1] startup
[5.108s] [ext: omni.kit.window.viewport-0.0.0] startup
2022-06-14 02:32:33 [5,713ms] [Error] [omni.hydra.pxr] Cannot use omni.hydra.pxr without OpenGL interop
[5.806s] [ext: omni.kvdb-0.0.0] startup
[5.807s] [ext: omni.ui_query-1.1.1] startup
[5.808s] [ext: omni.kit.window.preferences-1.2.1] startup
[5.836s] [ext: omni.graph.ui-1.6.1] startup
[5.852s] [ext: omni.kit.ui_test-1.2.0] startup
[5.854s] [ext: omni.graph.action-1.17.1] startup
[5.862s] [ext: omni.kit.widget.searchfield-1.0.6] startup
[5.863s] [ext: omni.convexdecomposition-1.4.13] startup
[5.864s] [ext: omni.localcache-0.0.0] startup
[5.866s] [ext: omni.usdphysics-1.4.13] startup
[5.868s] [ext: omni.graph.scriptnode-0.5.0] startup
[5.870s] [ext: omni.physx-1.4.13-5.1] startup
[5.947s] [ext: omni.graph.nodes-1.25.0] startup
[5.960s] [ext: omni.kit.usd_undo-0.1.0] startup
[5.961s] [ext: omni.mdl.usd_converter-1.0.0] startup
MDL python binding about to load …
MDL python binding loaded
[omni.mdl.usd_converter] MDL to USD converter startup
[5.963s] [ext: omni.kit.selection-0.1.0] startup
[5.963s] [ext: omni.rtx.window.settings-0.6.1] startup
[5.967s] [ext: omni.kit.compatibility_checker-0.1.0] startup
[5.968s] [ext: omni.kit.stage.mdl_converter-1.0.0] startup
[5.969s] [ext: omni.anim.camera_tool-103.1.2] startup
[5.972s] [ext: omni.anim.shared-103.6.12] startup
[5.977s] [ext: omni.anim.curve-103.7.10] startup
[5.981s] [ext: omni.hydra.pxr.settings-1.0.2] startup
[5.982s] [ext: omni.kit.menu.file-1.0.8] startup
[5.983s] [ext: omni.kit.window.provide_feedback-1.0.1] startup
[5.984s] [ext: omni.anim.timeline-103.0.3] startup
[5.987s] [ext: omni.kit.collaboration.channel_manager-1.0.2] startup
[5.989s] [ext: omni.kit.viewport_widgets_manager-1.0.4] startup
[5.990s] [ext: omni.kit.window.cursor-1.0.1] startup
[5.992s] [ext: omni.kit.window.about-1.0.1] startup
[5.993s] [ext: omni.kit.collaboration.viewport.camera-1.0.1] startup
[5.994s] [ext: omni.graph.examples.cpp-1.0.0] startup
[5.997s] [ext: omni.kit.widget.imageview-1.0.1] startup
[5.997s] [ext: omni.kit.search.files-1.0.4] startup
[5.999s] [ext: omni.kit.window.imageviewer-1.0.6] startup
[6.000s] [ext: omni.kit.tool.asset_exporter-1.1.7] startup
[6.003s] [ext: omni.anim.window.timeline-103.5.18] startup
[6.006s] [ext: omni.services.browser.asset-1.2.7] startup
[6.021s] [ext: omni.kit.widget.timeline-103.1.25] startup
[6.023s] [ext: omni.kit.widget.stage_icons-1.0.2] startup
[6.024s] [ext: omni.kit.widget.layers-1.5.17] startup
[6.032s] [ext: omni.kit.browser.asset_provider.actorcore-1.0.5] startup
[6.034s] [ext: omni.kit.window.title-1.1.1] startup
[6.035s] [ext: omni.anim.curve_editor-103.7.11] startup
[6.043s] [ext: omni.kit.mesh.raycast-103.7.3] startup
[6.048s] [ext: omni.kit.graph.delegate.default-1.0.15] startup
[6.049s] [ext: omni.kit.hydra_texture-1.0.3] startup
[6.054s] [ext: omni.kit.graph.usd.commands-1.0.0] startup
[6.055s] [ext: omni.kit.widget.zoombar-1.0.3] startup
[6.056s] [ext: omni.kit.graph.editor.core-1.3.3] startup
[6.058s] [ext: omni.kit.widget.material_preview-1.0.5] startup
[6.059s] [ext: omni.kit.renderer.capture-0.0.0] startup
[6.061s] [ext: omni.kit.browser.core-2.0.12] startup
[6.063s] [ext: omni.kit.window.material_graph-1.5.0] startup
[6.097s] [ext: omni.kit.thumbnails.mdl-1.0.12] startup
[6.106s] [ext: omni.kit.browser.folder.core-1.1.13] startup
[6.108s] [ext: omni.kit.window.quicksearch-2.3.1] startup
[6.110s] [ext: omni.command.usd-1.0.1] startup
[6.113s] [ext: omni.physx.commands-1.4.13-5.1] startup
[6.116s] [ext: omni.kit.browser.material-1.2.8] startup
[6.117s] [ext: omni.kit.property.material-1.8.5] startup
[6.119s] [ext: omni.kit.menu.edit-1.0.6] startup
[6.120s] [ext: omni.physx.ui-1.4.13-5.1] startup
[6.171s] [ext: omni.kit.window.material-1.0.17] startup
[6.177s] [ext: omni.kit.window.toolbar-1.2.4] startup
[6.181s] [ext: omni.paint.system.core-103.2.7] startup
[6.188s] [ext: omni.kit.widgets.custom-0.6.4] startup
[6.193s] [ext: omni.physx.demos-1.4.13-5.1] startup
[6.195s] [ext: omni.kit.property.physx-0.1.0] startup
2022-06-14 02:32:33 [6,192ms] [Warning] [omni.physx.plugin] Deprecated: getSimulationEventStream is deprecated, please use getSimulationEventStreamV2
[6.216s] [ext: omni.physx.zerogravity-1.4.13-5.1] startup
[6.220s] [ext: omni.physx.tests-1.4.13-5.1] startup
[6.310s] [ext: omni.paint.system.ui-103.4.6] startup
[6.315s] [ext: omni.services.facilities.monitoring.progress-0.2.2] startup
[6.317s] [ext: omni.kit.window.console-0.2.0] startup
[6.323s] [ext: omni.physx.vehicle-1.4.13-5.1] startup
[6.330s] [ext: omni.kit.activity.widget.monitor-1.0.6] startup
[6.333s] [ext: omni.physx.cct-1.4.13-5.1] startup
[6.368s] [ext: omni.services.transport.client.idl_http_async-0.2.0] startup
[6.368s] [ext: omni.physx.camera-1.4.13-5.1] startup
[6.373s] [ext: omni.kit.widget.collection-0.1.8] startup
[6.375s] [ext: omni.services.facilities.monitoring.metrics-0.2.1] startup
[6.381s] [ext: omni.kit.activity.model.file_status-1.0.5] startup
[6.382s] [ext: omni.kit.activity.model.usd_status-1.0.5] startup
[6.382s] [ext: omni.kit.activity.model.cache_status-1.0.5] startup
[6.383s] [ext: omni.physx.bundle-1.4.13-5.1] startup
[6.383s] [ext: omni.kit.property.collection-0.1.7] startup
[6.384s] [ext: omni.services.thumbnails.mdl-0.1.3] startup
[6.387s] [ext: omni.kit.quicksearch.material-0.8.6] startup
[6.389s] [ext: omni.kit.quicksearch.commands-1.1.3] startup
[6.389s] [ext: omni.kit.activity.progress.bundle-1.0.2] startup
[6.390s] [ext: omni.paint.brush.scatter-103.1.13] startup
[6.394s] [ext: omni.ui.scene-1.4.7] startup
[6.398s] [ext: omni.kit.quicksearch.settings-0.8.4] startup
[6.399s] [ext: omni.kit.search.service-0.1.3] startup
[6.423s] [ext: omni.graph.expression-1.0.0] startup
[6.426s] [ext: omni.paint.brush.scripting-103.6.6] startup
[6.467s] [ext: omni.paint.brush.modify-103.1.6] startup
[6.473s] [ext: omni.kit.manipulator.transform-1.4.0] startup
[6.477s] [ext: omni.kit.viewport.registry-1.0.2] startup
[6.479s] [ext: omni.kit.manipulator.viewport-1.0.6] startup
[6.480s] [ext: omni.paint.brush.attribute-103.3.3] startup
[6.486s] [ext: omni.paint.brush.select-103.1.2] startup
[6.493s] [ext: omni.kit.window.status_bar-0.1.1] startup
[6.496s] [ext: omni.videoencoding-0.1.0] startup
[6.499s] [ext: omni.kit.property.layer-1.1.2] startup
[6.500s] [ext: omni.kit.manipulator.prim-1.5.2] startup
[6.503s] [ext: omni.kit.quicksearch.select-0.8.3] startup
[6.504s] [ext: omni.paint.system.bundle-103.3.14] startup
[6.504s] [ext: omni.rtx.settings.core-0.5.5] startup
[6.507s] [ext: omni.kit.capture.viewport-1.1.9] startup
[6.510s] [ext: omni.kit.property.audio-1.0.5] startup
[6.511s] [ext: omni.kit.property.skel-1.0.1] startup
[6.512s] [ext: omni.kit.property.render-1.1.0] startup
[6.513s] [ext: omni.kit.property.camera-1.0.3] startup
[6.514s] [ext: omni.kit.property.geometry-1.2.0] startup
[6.515s] [ext: omni.kit.tool.collect-2.1.6] startup
[6.518s] [ext: omni.kit.property.light-1.0.5] startup
[6.519s] [ext: omni.kit.widget.sliderbar-1.0.10] startup
[6.520s] [ext: omni.kit.property.transform-1.0.2] startup
[6.522s] [ext: omni.kit.tool.asset_importer-2.3.20] startup
[6.525s] [ext: omni.kit.menu.aov-1.1.1] startup
[6.526s] [ext: omni.kit.browser.asset-1.1.7] startup
[6.527s] [ext: omni.kit.window.section-103.2.7] startup
[6.533s] [ext: omni.kit.environment.core-1.0.27] startup
[6.543s] [ext: omni.kit.property.bundle-1.2.4] startup
[6.543s] [ext: omni.kit.primitive.mesh-1.0.0] startup
[6.546s] [ext: omni.kit.widget.calendar-1.0.5] startup
[6.548s] [ext: omni.flowusd-0.1.0] startup
[6.554s] [ext: omni.iray.settings.core-0.6.3] startup
[6.559s] [ext: omni.kit.property.sbsar-0.8.0] startup
[6.561s] [ext: omni.kit.browser.asset_provider.local-1.0.7] startup
[6.563s] [ext: omni.kit.property.environment-1.0.13] startup
[6.565s] [ext: omni.kit.pointclouds-0.0.11] startup
[6.567s] [ext: omni.kit.window.movie_capture-1.2.12] startup
[6.570s] [ext: omni.kit.window.usd_paths-1.0.3] startup
[6.571s] [ext: omni.kit.quicksearch.actions-0.8.10] startup
[6.573s] [ext: omni.kit.window.environment-1.1.5] startup
[6.575s] [ext: omni.kit.graph.delegate.modern-1.6.0] startup
[6.576s] [ext: omni.kit.graph.widget.variables-2.0.2] startup
[6.577s] [ext: omni.kit.thumbnails.usd-0.5.1] startup
[6.579s] [ext: omni.services.starfleet.auth-0.1.2] startup
[6.584s] [ext: omni.graph.visualization.nodes-1.1.1] startup
[6.587s] [ext: omni.scene.visualization.core-103.4.1] startup
[6.594s] [ext: omni.graph.window.core-1.22.1] startup
[6.599s] [ext: omni.anim.retarget.core-103.1.14] startup
[6.603s] [ext: omni.graph.io-1.0.10] startup
[6.608s] [ext: omni.ramp-103.0.10] startup
[6.613s] [ext: omni.graph.instancing-1.1.4] startup
[6.617s] [ext: omni.graph.tutorials-1.1.2] startup
[6.627s] [ext: omni.graph.window.action-1.3.8] startup
[6.628s] [ext: omni.anim.graph.core-103.1.23] startup
2022-06-14 02:32:33 [6,610ms] [Warning] [omni.graph.core.plugin] Found duplicate of category ‘animation’ - was ‘Nodes dealing with Animation.’, adding ‘’
[6.633s] [ext: omni.particle.system.core-103.3.0] startup
[6.641s] [ext: omni.kit.window.stage-2.3.7] startup
[6.643s] [ext: omni.curve.creator-1.1.1] startup
[6.646s] [ext: omni.graph.bundle.action-1.0.0] startup
[6.646s] [ext: omni.kit.widget.searchable_combobox-1.0.4] startup
[6.647s] [ext: omni.graph.window.particle.system-103.1.14] startup
[6.649s] [ext: omni.particle.system.ui-103.2.0] startup
[6.656s] [ext: omni.curve.manipulator-103.4.0] startup
[6.665s] [ext: omni.curve.nodes-103.3.1] startup
[6.674s] [ext: omni.kit.browser.sample-1.0.5] startup
[6.675s] [ext: omni.kit.quicklayout-1.0.1] startup
[6.676s] [ext: omni.particle.system.bundle-103.2.20] startup
[6.676s] [ext: omni.kit.window.collection-0.1.8] startup
[6.677s] [ext: omni.anim.graph.ui-103.1.31] startup
[6.685s] [ext: omni.kit.browser.asset_provider.sketchfab-1.0.9] startup
[6.686s] [ext: omni.kit.window.script_editor-1.6.2] startup
[6.691s] [ext: omni.kit.window.extensions-1.1.0] startup
[6.694s] [ext: omni.kit.window.privacy-0.1.0] startup
[6.695s] [ext: omni.anim.skelJoint-103.2.20] startup
[6.698s] [ext: omni.anim.graph.bundle-103.1.4] startup
[6.699s] [ext: omni.kit.menu.common-1.0.0] startup
[6.700s] [ext: omni.create.app.resources-2022.1.0] startup
[6.700s] [ext: omni.services.usd-1.0.1] startup
[6.702s] [ext: omni.anim.retarget.ui-103.1.12] startup
[6.707s] [ext: omni.kit.quicksearch.hdri-0.8.8] startup
[6.708s] [ext: omni.kit.stage_column.variant-1.0.3] startup
[6.710s] [ext: omni.kit.sequencer.usd-103.1.4] startup
[6.712s] [ext: omni.kit.quicksearch.menu-0.8.6] startup
[6.713s] [ext: omni.kit.browser.asset_store-1.0.0-beta.25] startup
[6.716s] [ext: omni.anim.retarget.bundle-103.1.5] startup
[6.717s] [ext: omni.kit.widget.extended_searchfield-1.0.11] startup
[6.721s] [ext: omni.kit.widget.live-0.1.0] startup
[6.725s] [ext: omni.kit.sequencer.core-103.1.2] startup
[6.726s] [ext: omni.kit.preferences.time-0.0.6] startup
[6.730s] [ext: omni.kit.property.sequence-0.0.5] startup
[6.731s] [ext: omni.kit.profiler.window-1.4.4] startup
[6.734s] [ext: omni.kit.browser.asset_provider.turbosquid-1.0.7] startup
[6.735s] [ext: omni.kit.viewport.ready-1.0.1] startup
[6.736s] [ext: omni.kit.stage_column.payload-1.0.6] startup
[6.737s] [ext: omni.graph.window.generic-1.3.8] startup
[6.738s] [ext: omni.kit.quicksearch.props-0.8.5] startup
[6.738s] [ext: omni.kit.window.sequencer-103.1.9] startup
[6.753s] [ext: omni.create.app.setup-2022.1.0] startup
[6.755s] [ext: omni.kit.window.stats-0.1.1] startup
[6.756s] [ext: omni.create-2022.1.3-rc.10] startup
[6.929s] app ready
[11.709s] RTX ready
[61.048s] [ext: omni.kit.registry.nucleus-0.0.0] startup
[73.179s] Async pulling extension: modulus_ext.core-22.3.1 from the registry.
[omni.kit.registry.nucleus]: [omni.kit.registry.nucleus]: downloading: ‘https://kit-103-0-public-extensions.s3.amazonaws.com/public/3/archives/modulus_ext.core-22.3.1+lx64.r.cp37.zip’ → ‘/tmp/tmp2f1pl3hc/modulus_ext.core-22.3.1+lx64.r.cp37.zip’…
I have the same problem too
