Local Host issues
I am having issue creating a local host on my Nucleaus, waht culd be the cause?
Again, i don’t know if this is the reason why audio-to-face usdc refuses to work for my blender 4.2 when i export my usdc file, it just becomes blank on the audio-to-face app.
Even when all my configuration has been authenticated, yet I am still having this issue.
Here is the blank audio-to-face app, I keep clicking on the usdc exported from my blender, yet nothing happens, it;s just blank by default.
pleassseee helpppp.
When you installed Nucleus, it created an account for you, that is the admin by default.
If this doesn’t work, you can use omniverse:omniverse to fix your user account.
As for Audio2Face not loading the file, you should look in your Console window for errors. It’s possible there is something wrong with the file or it can’t find references. Verbose logs (the * in the Console) should give you more insight.
So sorry for the late reply and thank you so much for your swift response. However, above it an embedded image of the errors I keep encountering. it says it cannot read that my graphics card or it isn’t supported ([Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) UHD Graphics), despite the fact that I am using an Nvidia RTX3050 and it is currently turned on and I think i just set my graphics card to read the Nvidia Omniverse launcher, what could i be doing wrong?
I noticed that you have a space in your windows username. Normally that can cause a lot of problems with Omniverse. Your username ideally should have no spaces and no special characters. You can try to create a new windows username as a “test” and reinstall omniverse there.
Secondly, if you have a built in INTEL UHD graphics card, it is very important that you are sure you have not assigned it to the Direct 3D or Graphics Processing tasks. However, you have no actual RED warnings.
Finally, we no longer support Audio 2 Face here on this forum.
A2F
We’ve Moved NVIDIA A2F Support! We have new places to better help you get the support you need.
  1. Developers can submit tickets through the NVIDIA AI Enterprise program NVIDIA Enterprise Customer Support
  2. Developers can discuss ACE through our NVIDIA Developer Discord Server NVIDIA Developer
Ohk.
Thank you so much.
Would keep this in mind.
