After windows Update No longer to connect to Localhost
Hello, I have a new error I can not seem to solve; I can log into my user for Omniverse and sign in, but it says you’re ready to work. When I go into localhost, it says I failed to connect; I can not reconnect to the server.
look at the logs there are a few errors,
  1. 2024-08-12 07:07:30,269 nvidia.omniverse.cache.download_manager INFO Maintenance: deleted 0 FAILED and 0 COMPLETED task record
  2. 2024-08-09 16:28:17,229][OT] INFO: Listen.
    [2024-08-09 16:28:17,745][OT] INFO: Open HTTP session for healthchecks.
    [2024-08-09 16:28:20,777][OT] ERROR: Healthcheck: failed to ping port 8891 for Cache: Connection timeout to host http://localhost:8891/ping
    [2024-08-09 16:28:20,778][OT] ERROR: Healthcheck: failed to ping port 8892 for Cache: Connection timeout to host http://localhost:8892/ping
    [2024-08-09 16:28:20,779][OT] INFO: Healthcheck: retrying in 3 secs…
    [2024-08-09 16:28:26,801][OT] INFO: Healthcheck: Cache on ports [8891, 8892] is alive again.
    [2024-08-10 09:02:36,097][OT] INFO: Stopping Cache…
    [2024-08-10 09:02:36,146][OT] INFO: Starting Cache…
    [2024-08-10 09:02:36,160][OT] INFO: Stopping Cache Cleaner…
    [2024-08-10 09:02:36,175][OT] INFO: Starting Cache Cleaner…
    [2024-08-10 09:02:36,178][OT] INFO: Stopping Discovery Service…
    [2024-08-10 09:02:36,193][OT] INFO: Starting Discovery Service…
    [2024-08-10 09:09:19,235][OT] INFO: create_config_toml: <bound method MonitorConfig.create_config_toml of <monitor.config.MonitorConfig object at 0x0000021DEE751EA0>>
Your NVidia omniverse account log is not the same as your Nucleus localhost login. The Nucleus localhost uses the username and password you set up when you installed it. The default is “admin” and “admin” for both username and password if you forget. You can try that. If you cannot connect, you can simply remove the shortcut from your Omniverse apps, like Composer or Launcher and use “Add Server” and add back “localhost”. If it is setup correctly it should work. If it is not setup correctly and you have no important data that you will lose, you can simply delete your Localhost install and reinstall fresh.
Installing a localhost Nucleus server is not required for you to use Omniverse, its apps or its SDK. It is an optional download just for installing your own local Nucleus server and to test it out. It offers some demo files for use, but they are also available inside USD Composer. It is required for you to create a “Live” Session with some of our Omniverse Connectors, but not all apps and connectors support this feature.
there is not choice to add the server back, it has been working for 2 years after update it is removed.
there is not add localhost
Just click here and add “localhost”
Or here
I can not create a new localhost, it says failed to connect. this happened after the windows update on windows 11
Ok so uninstall and reinstall your entire localhost Nucleus from Launcher using the menu here. Then click the “Green plus” symbol to reinstall
Do you need a localhost Nucleus ? What are you using it for ?
OK, so uninstalling the local Nucleus server and re-installing it fix it. Yes having it is nice, does it not hold more data and version etc to the USD in the file.
thanks, Richard.
I mean yes, Nucleus may have some versioning, but so does OneDrive, Dropbox and even the normal Windows file system. Or you just save multiple versions as you go which I think is much safer. If Nucleus goes down, so does all of your data. I prefer to use normal file systems.
